Mowing JD X530 cuts out when engaging mower deck
   / JD X530 cuts out when engaging mower deck #1
mkbrown87
IN
John Deere X530
I own a used John Deere X530 with a 54" mower deck. I notice that if I try to engage the mower deck after just having started the JD, it will cause the engine to cut off. If I allow the engine to warm up a couple of minutes, then it will slow the engine until it fully engages the PTO, then come back up to RPM. Does anyone else experience this problem? Do I just need to allow the engine to warm up a bit first? Or is there something else that I need to look into? In advance, thank you for your help.
   / JD X530 cuts out when engaging mower deck #2
Yes, it happens to me, but not always. A new belt seems to make it worse as it grabs pretty hard and fast
   / JD X530 cuts out when engaging mower deck #3
My Ferris mower deck is hard to start the first time after setting for a while. I guess it is the stiff grease in the bearings that causes that. It takes a bit more throttle to get it started without stalling the engine. After running for a while, I can engage it with the engine at idle with no problem.
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
FUEL TANK (A50854)
FUEL TANK (A50854)
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
