JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #1
kw1600
washington
johndeere x324
Over two yrs, i have had a proplem when mowing. when cold pto engages intell it get warm. stop to dump grass. wont engage. cools down. will engage intell it gets warm, just put in a new jd clutch. still having problem. 500hrs on tractor. checked elect plugs. battery voltage. Is there a coil thats controlls the clutch?
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #2
SO---- What was the battery voltage? When stopped and when running?
well. i will check it tomarrow. when i mow. thank you
checked voltage. before start up. 12.88v. running 14.19v. pto engaged 13.06. pto kicked out 14.06v
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #5
Huh... well, there goes THAT theory~! IF you hadn't mentioned a new clutch, I'd have suggested that first. I GUESS that it's not IMPOSSIBLE for you to have a bad clutch pack - but with you just replacing it, unlikely...
Can you hook up parallel leads to the clutch electrical plug to measure voltage THERE, AT THE CLUTCH, while you're running?
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #6
Try bypassing the wires going to the clutch. Jerry rig some wires and a simple switch directly to the battery. Even though it acts like its a temperature related issue it could be a loose or broken wire/switch/connector/ground that acts up occasionally. I have had this type of thing stump me for days. Once a person thinks they know what the problem is, it is sometimes hard to step back and look at other possibilities. Happens to me all the time.
good luck
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #7
I have a X740 that will get hot from mowing and the PTO kicks out even though I pull the PTO switch before I back up. I found the problem was grass packed all over where it shouldn't be. It is water cooled and I have a temp gauge, but maybe you have a something plugged up causing it to heat up enough to where the electronic system kicks out the PTO. Just a thought. :confused3:
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
