JD X300 mower deck lift is reversed
   / JD X300 mower deck lift is reversed #1
Carlosvic
Hauser, ID
JD X300
Hey all,
Hoping someone can help me. I just removed the snow blower attachment on my X300 and installed the mower deck. Problem is the lift is reversed. When I release the locking mechanism the pedal drops all the way down with the deck lowered. I have to physically pull on the pedal to raise the deck and then lock it into that position.
I followed the directions in the owners manual and can't quite figure out how to get it right.
Any suggestions would be appreciated.
   / JD X300 mower deck lift is reversed #2
it may be a simple adjustment,
there should be a spring assist adjustment that you adjust at the front bumper. along the right side
of the frame ( near the front axle) there is a guage to select the proper spring assist adjustment. that setting
depends on the deck you have. i'd start there, make sure that is adjusted to your deck size, 42 or 48.
also, using the lift lock in reverse is part of removing the mower deck, you pull the lift pedal up towards the
seat, and use the deck lockup lever to hold it all the way back, removing the spring pressure off the lift
arms for mower. when you put the deck back on, after all the pins are in and the belts are on, you use that
pedal and it's lock to put the system back into normal operation mode, which should include some lift assist.
then, with your foot, pushing forward on that pedal should again raise the mower, allowing you to lock it in
the raised position with the handle. as the install is happening, be sure your mower dial is set to 0/install
double check your spring adjustment and procedure and check back with us,,, which deck do you have?
was the unit all purchased new, assembled? or did you install the blower last fall?
and welcome to TBN!
Thank you Dutch, I will try this tomorrow.
The unit is new and the dealer installed the blower prior to delivery. The deck itself is 42".
I'll let you know what happens.
   / JD X300 mower deck lift is reversed #4
I'm sure Carlosvic has already figured this out, but I'm posting here for anyone else that runs into this. The "problem" is that the dealer installed a spring-assist lift kit on the x300 to handle the extra weight of the snow blower, and it was adjusted with too much tension for the mower deck. If you look along the lower starboard side in the vicinity of the engine compartment, you'll see a decal with the different options listed, such as for a 42 or 48 inch deck, blade, etc. The adjustment bolt is in the front of the tractor. Take a look at this video that goes through the spring-assist unit install, which should give you enough clues to figure out how to take the tension off the spring-assist for your mower deck.
I had exactly the same thing happen to me in the springtime when I tried to switch over from my new dealer-installed snow blower.
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
UNUSED FUTURE FT13CJ EXCAVATOR (A51247)
UNUSED FUTURE...
