JD X series LED's
   / JD X series LED's #1
erieskidoo
Erie, PA
John Deere X728SE
Has anyone put any LED's on their X Series? I was thinking about adding some for safety when on the road, and maybe a work light.
   / JD X series LED's #2
I thought about it when I first bought mine but the existing lights seem to work well enough for me. My tlb is the one that works in the street so I did install the strobe on it. I also have some large cones to put out when working at the curb too.
   / JD X series LED's #4
Get 1 or 2 of these, Cheaper and it does the Job... Works great for me... Mount 2 of them with a $3 Off / On Switch... You are all set...
The Power Rating on them is NOT too bad either about 1.7amp, it doesn't suck too much. But if you are looking for Direct Lighting, like Headlights... Than these are NOT for you. These lights will light up good but it will disburse evenly rather than Head-On...
Although $16.49 each with Free Shipping is NOT bad, compare to those LED lights they are selling for Tractors.... Search on Ebay 10W White LED Flood Light Washlight - 12V DC or Item 110836734037
Easy to Mount since it has predrilled holes...
Good Luck with whatever you decided!!!
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2005 Great Dane GPLWSAR-248-102 48ft 35 Ton Flatbed Equipment Trailer (A52377)
2005 Great Dane...
2016 BOBCAT S770 SKID STEER (A52705)
2016 BOBCAT S770...
