JD X-304 Runs Intermittently
   / JD X-304 Runs Intermittently #1
budlite
Toney, Alabama
NH Workmaster 75
Starts and runs good for about 30 mins, then dies, won't start. If it sits for a couple hours or more, same thing, starts and runds good for 30 mins then dies. Already cleaned carb, have Stabilizer in the gas. Any ideas?
   / JD X-304 Runs Intermittently #2
No experience with Kawasakis, but try opening the gas cap to vent tank.
Maybe the ignition coil is getting hot and failing. Try cooling it with compressed air or a fan to see if it will start sooner.
Same with carb. or fuel pump that has a vapor lock.
Might call the dealer to see if there are any known issues with this particular engine.
Good Luck.
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2014 Nissan Juke (A53424)
2014 Nissan Juke...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2011 John Deere 120D (A47477)
2011 John Deere...
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
