JD tractor armor
/ JD tractor armor #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
Several months ago( maybe a year) someone posted about a JD add-on grill guard and hood protecter for working in the woods and /or with a loader. I remember him saying it was buried on the JD Web site and he had a link. I thought he called it "tractor armor" I've searched the JD Web site but come up blank. Can the TBN braintrust, yet again, help me?
/ JD tractor armor #2
Ray,
I think the thread you're thinking of may be <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=jdown&Number=39899&page=&view=&sb=&o=&vc=1>this one</A>. Good luck trying to find the hood armor on the J.D. site. I've never been able to find it even though the extra armor package shows it.
Hoss
/ JD tractor armor #3
I think this is what you are looking for...
<A target="_blank" HREF=http://www.tractorbynet.com/news/040201_deere_xtra.shtml>http://www.tractorbynet.com/news/040201_deere_xtra.shtml</A>
/ JD tractor armor #4
RCH, last fall i got the "JD Xtra Armor Kit" for my 4400. The dealer tried charging me extra for the cutting edge for the bucket, and the guard for the mid-point hydralics which you see are included in Mikes attachment. WARNING! Mid-point hydralics guard DOES NOT work if you install the 6-ply 7-16" r-1 front tires! After coming out to install the guard, i started up my tractor and pulled out of the barn and made a right turn........ only to have the front end jump then dive scaring me half to death! i immediatly shut down the tractor and did a "walk around" and found the front right wheel had drove itself under the guard with the weight of the tractor on top! If i had turned the wheel to the right further than i had i would have torn the tire of the rim or even the entire wheel off the tractor! Called the dealer and they sent out their sv mngr who pulled off the guard three times to rebuild so it would fit proper! As for the kit in general, i like it although a skid-plate covering the entire bottom of the tractor would be nice........i spent the first 8 hrs running an MX-5 rotary cutter, brushing NEW trail thru the woods and running over trees as thick as my wrist the guards seem to be doing their job.................. mark
/ JD tractor armor
Randy, Mike, Mark; you guys are great. That is exactly what I was looking for.
Mark, do you have any cost figures ? What exactly is included ? Would a 4 n 1 bucket complicate things (is that what you mean about a mid mounted hydraulic ?) Re your comments about a skid plate, what do you recommend ? Does this interfere with access to the engine, checking the battery, radiator, cleaning debri off the radiator etc. Please elaborate about the 6 ply tires hanging -up and what is the fix, if there is one? Would a 4300 have the same concerns ?
/ JD tractor armor #6
Hey Ray, sorry i didn't get back sooner. The cost for the entire kit was $615.00. Everything that was included was in the down-load i got off of the JD websight. The dealer didn't want to include everything you see.( he tried charging me cutting edge for bucket, warning light brush guards, and tried to tell me that the mid point hyd. guard was not included.....also extra) He didn't appreciate me confronting him with the print out from JD. Seems his dealers book had differant info. As for the skid plate, thats something one would have to mfgr one self. I haven't really looked to closely at it yet. The only way to keep away from the 6-ply tire/mid-point guard conflict is to either not get the tires or not get the guard... or...do what we had to do, and that means remanufacturing the guard so there is no conflict.... 4300 would have the same concerns because the only real differance with the 4400 and 4300 is a couple of hp. will try to send some pics.......... hope this helps.................mark
/ JD tractor armor #7
..............Mid point hyd guard, had to be shortened approx. 4"........
/ JD tractor armor #8
....tie down attachments and kevlar covers...........
/ JD tractor armor #9
..............protective plates for hyd cylinders....................
/ JD tractor armor #10
..........hood and grill guard...........
/ JD tractor armor
MarkinMN, thanks re photos. Now I understand about the big tires and hydraulic coupling. What about accessing engine compartment?
/ JD tractor armor #12
Hey Ray, Getting access to engine compartment is a snap! The hood/brush guard, is mounted by 4 pins in front. To open it, just remove the top 2 pins (pull the hitch-pin clips first) and lift and swing, forward the guard up,over and down and let it rest on the loader horizontal member the bottom pins act as hinges.................hope this helps...........mark
/ JD tractor armor #13
.........................and "TA DAA"........................
/ JD tractor armor #14
16 March 2001
Commercial-01-20
Tractors
Commercial & Consumer Equipment
Marketing Information Bulletin
1 Litho in U.S.A.
Date
Number
Product Line
XTRA ARMOR TRACTOR PROTECTION KIT
John Deere Augusta is pleased to announce that the tractor portion of the Xtra Armor
protection package will be available for the 4000 Series Compact Utility Tractors. The John
Deere Xtra Armor protection package provides maximum protection to vital tractor and
loader components when used in harsh work environments. Kit contents can be ordered
complete (separate kit for tractor and loader) or as individual items.
Please reference MIB Commercial-01-1, dated 10 November 2000, for loader portion
ordering codes.
The entire tractor protection package contains ROPS warning light guards, backup alarm,
SCV line guard, and rental upgrade, which includes a high-speed lockout and ROPS lock.
Order:
Effective: 1 April 2001
Bundle Description
LVB25154 4200-4400 Complete Xtra Armor Kit
LVB25155 4500-4700 Complete Xtra Armor Kit
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
2017 Chevrolet Malibu Sedan. (A61574)
2017 Chevrolet...
2022 EZ-GO ELITE...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2022 EZ-GO ELITE...
Forklift (A56857)
Forklift (A56857)
