JD SU20768 & RE253518 Air Filter DIFFERENCE
/ JD SU20768 & RE253518 Air Filter DIFFERENCE #1
Brown Dog
Veteran Member
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
My 5093E 5101E both takes the RE253518 Air Filter which looks IDENTICAL to the SU20768 in my Newer 5085E.
WHAT is the Difference ? Different filtering qualities :confused:
Napa 9275 replaces BOTH of these filters.
/ JD SU20768 & RE253518 Air Filter DIFFERENCE #2
Can't find any specs in JD, so I can't tell you. Strange since both models call for the same secondary air filter. The complete filter housing assembly shows a different part number as well. It wouldn't be the first time I have seen 2 or more different part numbers for the same part.
/ JD SU20768 & RE253518 Air Filter DIFFERENCE #3
I wonder if from a different vendor, hence a different P/N?
I would use the latest P/N, hoping JD improved it, not cheapened it.
