JD slash bundler machine
/ JD slash bundler machine #2
New one on me too. Apparently, the bundles are on their way to a chip mill and bundling the slash lowers the transportation cost.
Dave.
/ JD slash bundler machine #3
I wonder how large material can be for that machine? It seems that a logging operation might leave some very large tops laying around that would be too big. Don't know. . . .
When I went to your link, I also saw this sugar cane harvester. This machine really fascinates me because it first tops the cane, then cuts and separates the cane from the leaves/chaff. Don't you know there's some sweet juice running out of the bottom of that dump wagon before it gets its load to the processing plant? I wonder if this machine is at least 90% efficient?
I saw the cane harvester too. It's amazing the crazy stuff people have invented.
/ JD slash bundler machine #5
That is a neat machine - but I bet you sure have to invest a lot of cash to bundle that junk up. Wonder if there is a market for the bales it makes???
/ JD slash bundler machine #6
Those bundles are only burned at biomass energy plants due to the high amount of extra green content. Wood chips used for plywood and paper are made by machines that delimb the trees and take off the leafy branches and sometimes bark leaving a high quality pulpwood chip.
/ JD slash bundler machine #7
They sometimes do that down here with the slash. The problem is...taking all the debris is taking needed nutrients that would break down and go into the soil and grow more trees. I have read a recent study about this. A working forest can only take a couple clearcuts with the slash removed before the soil becomes too depleted to regrow another planting successfully. I know some of the big timber companies down here rotate their slash removal on their plantations. Same goes for taking pine straw year after year on a plot.
/ JD slash bundler machine #8
Redbug
That is true for short rotation plantations, like in the south. But this Deere machine is touted to be for hardwood forests where the rotations are 80 - 100 years. So annually the leaves fall to the ground and add nutrients. Removing the tree in the 100th year doesn't have much effect on the soil nutrient loss.
But many enviros will use this approach to try to stop all logging and tree removal.
Some say that biofuels are coming, but I don't think there is anything on the drawing board that can compete with coal. So much more energy per volume of coal than per the same volume of biomass, that moving biomass any distance at all will either make it economically impossible, or there will have to be huge amounts of taxpayers money to finance it (at a loss). IMO
I think Deere has gone the extra to at least have the equipment ready for any biomass removal (when and if that time comes).
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2023 TAKEUCHI TL10V2 SKID STEER (A65056)
2023 TAKEUCHI...
PAIR OF TRACTOR TIRES AND RIMS (A67714)
PAIR OF TRACTOR...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
2012 KENWORTH T800 HYDROVAC (A67714)
2012 KENWORTH T800...
