JD Sabre 17 hp (1742)
   / JD Sabre 17 hp (1742) #1
Dan Holland
John Deere Sabre 1742 17hp
Starts & runs properly until you let the Clutch/Brake pedal out and then it stops immediatley.
(rather like a kill switch has been enacted)
Has anyone had this happen ? Any ideas ?
Thanks
Danbo
   / JD Sabre 17 hp (1742) #2
First, "Welcome to the forum".:)
So Dan, have you checked the various interlocks for continuity? It may be as simple as a loose connection on a switch. I would check the seat switch to make sure it is working, if it doesn't make contact thru it to indicate operator is in the seat it will stop the tractor. These seat switches do go bad quite often.
Thanks Steve,
I'll check those out this weekend, I'm hoping it's something simple like that.
DAN
Thanks Steve - That did the trick ! It was a faulty kill switch under the seat !
Simple, just the kind of repair I like !
Thanks again,
Dan
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
