JD QuickAttach building
   / JD QuickAttach building #11
Guys:
I have a 420 loader on my 4310. What part numbers for the hooks and pins did you use? I want to build a quick tach frame to mount 3 pt tools to, so I can put a landscape rake on the front and reach under trees and pull trash out (one example).
Never mind. Found 'em.
Hook W43359 $12.38 ea
Pin W47211 $14.86 ea
   / JD QuickAttach building #12
Guys:
Those are the correct part numbers-BUT the price has apparently more than doubled!
I actually completed the build with the 4x4 that I had. It's simply a rectangle with quick-attach for JD, and some angle to mount my existing rear bale spear to. I think it will serve it's purpose.
I actually have enough 3x3 x 3/16" thick square tubing to make another but wasn't sure if that would be heavy enough. I'd probably run a 3x5 in the center for the center bale spear kit to be welded to.
It definitely isn't pretty. ;)
   / JD QuickAttach building #14
I'm fixing to do the very same thing. Initially used my FEL as the anchor point. It worked but I'm not happy with it. Will be doing this build with 4x4 as when done will be a universal mount for anything I can even emagine that I could mount to it. Moving 1500lb bales puts a lot of strain on welds and material.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
2007 Terex (A55973)
2007 Terex (A55973)
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
