Planters JD Planter Question
   / JD Planter Question #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I bought an old JD 246/247 planter. It's in pretty rough shape and I'm doing some rebuilding and refurbishing. The chutes in which the fertilizer flows through to the ground are metal spiral cylinders. Both are rusted beyond repair. I have seen some rebuilt planters that have plastic tubes that replace the metal ones. Are those available through JD? Are they possibly aftermarket replacements? If so, any ideas about where they can be found? Any ideas/suggestions are appreciated.
   / JD Planter Question #3
Let me know what you find.. mine are in pretty bad shape too. Thankyou!
kensfarm.........Shoup carries some aftermarket plastic ones, not too expensive, about $6.50 each. I assumed they were the answer, but after looking at the way they need to attach at the bottom, I'm not sure. Go over to ytmag.com and read a similar post in the implement alley forum to the one I posted here. There were some answers and suggestions that might be helpful.
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2020 KUBOTA RTV...
2019 CASCADE DM0B1300 HYD BALE CLAMP (A51243)
2019 CASCADE...
