JD pallet fork attachment equivalent?
   / JD pallet fork attachment equivalent? #1
cruzr
East Central Missouri
J.D. 3320 / Ford 900
Hi all, I have been looking for a quick change fork attachment for the 300cx loader. I was quoted $825 for the J.D. fixed fork attachment. Is there a less expensive brand that will still use the J.D. quick attach? Thanks for viewing.
   / JD pallet fork attachment equivalent? #2
Some here have posted pics of homemade equivalents, and they look good. Just duplicate the bucket connecting points and you should be able to attach it to any fork set-up you find.
I think the Deere forks would be hard to beat, however. They aren't cheap, nor are they built cheap. /forums/images/graemlins/wink.gif
   / JD pallet fork attachment equivalent? #3
I went to the skid steer carrier and Worksite Pro forks. That skid steer carrier is awesome! The skid steer attachments are typically built heavier AND less expensive...
   / JD pallet fork attachment equivalent? #4
I welded up some very stout homemade forks. Then I went to JD and bought the bucket quick-tach brackets and pins ($35) and welded it to my fork assembly. Works great and the quick attach is fantastic.
   / JD pallet fork attachment equivalent? #5
jy Do you happen to have the Deere part numbers for those bracket parts? I have some plans that they would come in real handy.
Thanks
   / JD pallet fork attachment equivalent? #6
They're in the JD loader attachment section on deere.com/. HTH
   / JD pallet fork attachment equivalent? #7
Go to TractorPoint.com And read Denwood's posting on 4110 pallet forks, as he has all the information needed!
Bob J
   / JD pallet fork attachment equivalent? #8
That was a 'deadend' and time consumming search for me, with nothing coming up. Each search within led to 'zip', nada.
Do you have a URL or link to the site you mentioned that showed the parts? or the part numbers themselves.
Thanks
   / JD pallet fork attachment equivalent? #9
I did Google search found on first time
JD part No.W43359-Hook @2 $10.36 each
JD part No. W45253-Reinforcement Strap @2 $5.09 each
JD part No.W47211 Pin @2 $4.95 each
Go to JD parts to confirm this or do your search and get the whole story!
   / JD pallet fork attachment equivalent? #10
Thank you very much for that information. /forums/images/graemlins/wink.gif
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
