JD MX-6 repair
   / JD MX-6 repair #1
farmglide
Brookfield MA
JD 4320
I just finished repairing my JD MX-6 rotary brush cutter after the output shaft snapped as many others have done.
I found a 150HP gear box at D&N equipment in Ohio that I was able to use with a little modification to the deck ( adding two mounting holes and elongating the existing four) and the stump jumper ( drilling the center hole out to 1 1/32 and counterboring the bottom 1 1/2 dia X 7/16 deep. The counterboring is because the new gear box has a threaded shaft and the stumpjumper is held on with a 1" jam nut with red lock tight. If the threaded shaft was a little longer you could use the castle nut provided.
D&N told me they also have a 75HP unit that requires less work to install but I wanted to go big so I don't have to worry about doing this again. The new gear box is massive!! but dropped right inplace.
All in the repair cost me $1000 or less than half what JD wanted and now i have a 150HP gear box and the satisfaction of fixing it myself and not giving JD another dime to fix something that is clearly their poor part quality.
I used the cutter for a few min after assembly and it worked fine!
FG
   / JD MX-6 repair #2
Glad you got it done.
Considering that your tractor is less than 50hp, that 150hp gearbox should last a while. :D
Just curious. I read the other posts on this repair, but I didn't see anything about a slip clutch. Does your unit have one, did you adjust it prior to the shaft failure, and is it working properly?
   / JD MX-6 repair
BIGFOOT62
Yes there is a slip clutch and I followed the adjustment procedure to ensure it was not frozen up with rust.
when I posted before I forgot i had to purchase an adaptor to mate the new gear box to my drive shaft. the gear box input splined shaft is a larger diameter so I needed to go up in size. That was another $150 so total cost of the repair was more like $1150.
RG
   / JD MX-6 repair #4
BIGFOOT62
RG
Sometimes the slip clutch just won't do it, but your chances are better with one than without one.
Sounds like your case it was just a weak part.
At any rate, glad you got it back up and going. Doing it yourself and saving a few bucks always feels good. :thumbsup:
2024 John Deere 410R Sprayer (A53342)
2024 John Deere...
2021 JOHN DEERE 2032R TRACTOR LOADER BACKHOE 4X4 (A51247)
2021 JOHN DEERE...
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3226...
John Deere HPX615E Gator 4x4 Utility Cart (A51691)
John Deere HPX615E...
