farmglide
I just finished repairing my JD MX-6 rotary brush cutter after the output shaft snapped as many others have done.
I found a 150HP gear box at D&N equipment in Ohio that I was able to use with a little modification to the deck ( adding two mounting holes and elongating the existing four) and the stump jumper ( drilling the center hole out to 1 1/32 and counterboring the bottom 1 1/2 dia X 7/16 deep. The counterboring is because the new gear box has a threaded shaft and the stumpjumper is held on with a 1" jam nut with red lock tight. If the threaded shaft was a little longer you could use the castle nut provided.
D&N told me they also have a 75HP unit that requires less work to install but I wanted to go big so I don't have to worry about doing this again. The new gear box is massive!! but dropped right inplace.
All in the repair cost me $1000 or less than half what JD wanted and now i have a 150HP gear box and the satisfaction of fixing it myself and not giving JD another dime to fix something that is clearly their poor part quality.
I used the cutter for a few min after assembly and it worked fine!
FG
FG
