JD model 39 sickle bar
/ JD model 39 sickle bar #1
robyoak
Webbville KY
Ford 4000SU
Does anybody have or know where to find parts for a JD model 39 sickle bar. The upper pulley has busted on mine...again. It痴 been welded several times and this time it痴 done for. It痴 a discontinued part and I致e searched high and low for one. Thanks
/ JD model 39 sickle bar #2
Welcome to TBN
Although very pricey pulley for 540 rpm operation is still available from JD. AE31166 Pulley - ADD 816.02 USD
I think according to the serial number, they made 2 or 3 different pulleys. My local JD dealer showed me that the one I need is discontinued. But even if I could get one, I won稚 be paying that for one.
/ JD model 39 sickle bar #4
Use the ratio of the drive to driven sheave diameters to get an equivalent sprocket set and run a chain instead of a belt.
If you still have a decent center hub portion, bolt another pulley along side it. Looks like there is plenty of spline shaft to space the new pulley in a position to work. 39 sheave.JPG If the center hub is shot, find a new hub that fits and bolt on the o.e.m rim.
Let us know what works out. We like the Rube Goldberg solutions !
The center is what is busted into several pieces, and it痴 a strange offset pulley. I値l send some pics when I get a chance. I will McGuiver something and make it work. Thanks
/ JD model 39 sickle bar #6
Yes but if one reads parts description first part number listed subs to part number I posted for 540 pto operation. I was taught back in the 60's when I started employment at a JD dealership when working in parts dept I was instructed to read all parts descriptions & footnotes.
/ JD model 39 sickle bar #7
What we do is send the broken part to a local machine shop, so they can use it as a template for a new part. Steel parts last longer than cast and can take more stress.
/ JD model 39 sickle bar #8
I’d look for another one for parts, or upgrade to another model,
/ JD model 39 sickle bar #9
I would recommend making a post on Yesterday's Tractor forum. That site will serve you better when looking for vintage stuff. This site is more modern compact tractor based.
/ JD model 39 sickle bar #10
I know you are probably dealing with a unique spine but you could still probably get away with a Browning hub and pulley set up.
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
CARORI 4' FINISH MOWER, 3PT (A64278)
CARORI 4' FINISH...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2018 INTERNATIONAL...
2016 Chevrolet Tahoe SUV (A64194)
2016 Chevrolet...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
