JD MOCO 1207
/ JD MOCO 1207 #1
DevinMF165
North Carolina
MF 165 & MF3525
I bought a mower conditioner that is a JD 1207. The seller tells me it is out of time. How can I set the timing? I have a owners manual ordered.
Thanks
Devin
/ JD MOCO 1207
Thanks
Devin
/ JD MOCO 1207 #3
Under the hood where the drive line goes in, there's an L shape gear box. Look down on the bottom roller shaft and you'll see two round plates bolted together(on short drive shaft) with slots in them. I think there's carriage head 3 bolts. You can loosen those bolts and advance or ****** the bottom roller to make the treads fit between the treads on the top roll. There should be an even spacing between those treads.
I ran a 1217 for 15 years and I'm pretty sure the 1207 is the same.
Also after you get those rollers timed, start the machine up. If it's rumbling loud the rollers may be to close together. The adj. rods and nuts for that is on top near the reel. One on each side. If I remember correct you lower the roller until you hear the noise start to get louder from the contact between the rollers. Then back it away so many turns per the manual you have. Can't remember how many turns(think it's 1 and 3/4, could be wrong). Those nuts are nylon locking and stay where you leave them.
The pressure setting is under the hoods on both sides. There's a threaded rod with jam nuts on it. Your machine may be a little different but I know I helped set up a 1209 and it was the same as the 1217.
Hope this helped. If it didn't I may be able to take some picture of a 1209 in those adj. locations.
/ JD MOCO 1207 #4
/ JD MOCO 1207
I have not recieved my manual yet. I would like to thank you for your reply. I yu could post some pictures well that would be great /forums/images/graemlins/cool.gif. I am new to these machines and not sure of the points that you refer to.
Thank you again
Devin
/ JD MOCO 1207
Thank you again
Devin
/ JD MOCO 1207 #7
I'll call my neighbor and see if he still has that 1209. If so I'll try and get some pictures. Tomorrow read what I wrote and go out and look at the machine. I bet you'll see the plates I wrote about. Once you get the bolts loose you can go under the rear hood and move the roller with your hand. Get someone to hold the roller once you get it right and then tighten the nuts down good.
/ JD MOCO 1207 #8
/ JD MOCO 1207 #9
Well my neighbor doesn't have the 1209 these days. He traded it in on a disc conditioner.(JD) So I can't get the pictures.
/ JD MOCO 1207 #10
/ JD MOCO 1207
Thanks for your help. I think that I know what you are atlking about by looking at the mower. I am planning on working on it Friday.
Devin
/ JD MOCO 1207
Devin
(4) F150 RIMS W/ GOODYEAR WRANGLER 275/65R18 TIRES (A64276)
(4) F150 RIMS W/...
Case TV380 (A62177)
Case TV380 (A62177)
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
John Deere 15' PT Batwing Mower (A64126)
John Deere 15' PT...
(5) 10 X 20 STEEL MATS (A64276)
(5) 10 X 20 STEEL...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
