JD M665
   / JD M665 #1
Rickcooksey
Williston tn
M665 z turn
I have a JD M665 Z turn
The right drive wheel reverse speed is slower than the forward speed. What could cause this?
   / JD M665 #2
:welcome:
And you suspect this because the handles are not across from each other when going in reverse?
Or something else?
Seem okay going forward?
   / JD M665
Yes I have suspected it for some time because of the inconsistance in the steering. I jacked it off the ground and could tell then the speeds were different.
   / JD M665 #4
I believe there are adjustments to fine tune the handle position and the hyd. motor speeds.
Either the Deere dealer can do for you, or get the tech manual if figuring on doing your own work.
Or, if a member here has the procedure and will share it.
2018 KENWORTH T680 SLEEPER (A54607)
2018 KENWORTH T680...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2019 FREIGHTLINER CORONADO MIDROOF SLEEPER (A54607)
2019 FREIGHTLINER...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
