JD LX5 Sheer Pin
   / JD LX5 Sheer Pin #1
mapmgr
NE OKC, OK
JD 4310 eHydro 4WD
Hi everyone,
Novice here, so dumb question(s)...
I have a JD LX5 rotary cutter. It appears that the sheer pin did what it was supposed to do when the cutter grounded out.
I went to a local JD dealer (small stuff only-- garden tractors, gators) and they didn't carry the pin. It was suggested that I go to Lumber 2 to try to pick one up. Went there, and couldn't find anything that specifically said sheer pin.
Is this the same as a cleavis bolt with cotter pin? If so, what size, or do I need to travel a bit to the JD with larger stuff or some place else?
Also, do I ever need to change the oil in the gear box?
Thanks.
-- Glenn
   / JD LX5 Sheer Pin #2
A shear pin, is a bolt. I have a spare for my lx5, but I can't remember what size it is. It seems that it is metric equivalent to a grade 5 bolt. JC
   / JD LX5 Sheer Pin
Thanks for the info!
-- Glenn
Spreader Attachment (A56859)
Spreader...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
John Deere XUV825E (A56438)
John Deere XUV825E...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
