JD LX 280 Advice ?
   / JD LX 280 Advice ? #1
PatBenkert
Muskegon, MI.
FarmTrack 555 DTC
I picked up a JD LX 280 AWS. It has a 18 HP. Kawasaki motor and the edge 48"deck. I want to fit with a bagger or a material collection system. Question is, has anyone tried to use a regular 2 or 3 bagger hopper style? Or do you have to use the power flo system? I would appreciate any feed back.
   / JD LX 280 Advice ? #2
Any Deck over 42" requires the Power Flow System.
   / JD LX 280 Advice ? #3
Not necessarily on the Powerflo. I would think that you have a 48C deck though which Deere's standard bagger has the Powerflo. An Edge deck if you happen to somehow have that doesn't. You will see that the lighter tractor series L-E with the 48 edge doesn't have a Powerflo bagger available. It won't be a bolt on affair I'd think. Could probably be done. Should be done? Others bag with 48 /54" decks w/o an assist blower, but require nice high lift blades. Post a pic of your deck if you are not sure.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
UNUSED FUTURE 15" EXCAVATOR GRAPPLE (A51248)
UNUSED FUTURE 15"...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
