JD LT180 or LA145
   / JD LT180 or LA145 #1
microcosm
I am looking to get a new/used mower and have narrowed it down to 2 options and would like to hear opinions on which one to pick.
1. LT180 2005 w/150 hours, bagger and 42" deck. $1950 out the door
2. LA145 new w/0 hours, no bagger and 48" deck. $2000 out the door
Thanks in advance,
Mike
   / JD LT180 or LA145 #2
Unless you feel that you have to have the warranty the lt180 is twice the machine. The kawi powered units are so much nicer as well as a longer life machine. New a lt180 with a bagger should have been $3,000 so nothing wrong with trying to get them to 1/2 of new.
   / JD LT180 or LA145 #3
I'm a LA145 owner. The deck on mine is not what it should be. I just had one of the main spindles crater (as in the aluminum casting broke in half). I grease spindles every 8-10 hours and I only have 90 hours on my mower. Also, the engine carburetor has had terrible problems with ethanol and bad seals and needle valves going bad. For $2000, I find it just barely acceptable. I would have to recommend the used LT180. I can no longer recommend the LA145 in good faith. Sadly, it requires lots of skill and spare parts to keep running.:(
   / JD LT180 or LA145
Guys,
Thanks for the responses. You pretty much echoed my thoughts.
Mike
   / JD LT180 or LA145 #5
You will have problems with ethanol blended fuel in either of these products stick with low grade or premium for best results.
2013 MACK CXU (A50854)
INGERSOLL RAND G40 GENERATOR (A50854)
INGERSOLL RAND G40...
71065 (A49346)
71065 (A49346)
500BBL WHEELED FRAC TANK (A50854)
500BBL WHEELED...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2022 Ford F-250 XL...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
