JD LT170
   / JD LT170 #1
indianajeffrey
Plymouth
JD170 and a Cub Cadet ZForce Contractor
Hi all, joined this forum because I am at a loss with my JD LT170. It appears I am not getting fuel to the fuel filter, I checked the spark plugs and cleaned them, pulled the bowl on the carb and cleaned it, oil, gas, is all fresh. When I crank over the mower it's getting good spark but the fuel filter is empty, just noticed it today while trying to get it going. Could it be the fuel pump, does it have a fuel pump? :confused:
   / JD LT170 #2
There is no gas tank type fuel pump. The manual indicates there is a fuel shut off solenoid on the carburator. I have the TM on the LT series if you need it.
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2006 Chevrolet Impala Sedan (A55853)
2006 Chevrolet...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
