JD Loader "Quik-Change" vs. skid-steer?
   / JD Loader "Quik-Change" vs. skid-steer? #1
timb
Southwest PA
Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
JD Loader \"Quik-Change\" vs. skid-steer?
I thought that this was gone over before, but I haven't had any success searching the forums on this one... (if this has already been discussed can someone point me to the right thread?)
Is the JD "Quik-Change" loader attachment system compatible with industry-standard skid-steer attachments or not? (ala NH loaders)
If not does anyone make a commerical adapter?
If I'm understanding this correctly, conceptually it's the same thing - but I can't find any info on specifically how the "interface" works or dimensional data of the two (?) systems.
Thanks,
Tim
   / JD Loader "Quik-Change" vs. skid-steer? #2
Re: JD Loader \"Quik-Change\" vs. skid-steer?
The 110 TLB have SSL style Q-T but I think the rest of CUT
have Deere own style (not interchangable).
Kasco make a SSL Q-T that goes on loader pins for most loaders.
http://www.kascomfg.com/hitching_equipment.htm
I don't know about an adapter.
   / JD Loader "Quik-Change" vs. skid-steer? #3
That is why I got a GB loader, skid steer compatable. by now I would think somone makes a adapter.
   / JD Loader "Quik-Change" vs. skid-steer? #4
Are there any advantages to the Deere setup over the skid steer?
   / JD Loader "Quik-Change" vs. skid-steer? #5
The reason I got the skid steer set up is the 4000lb pallet forks cost me $600 instead of $1000.
I personal like the skid steer type. if it is strong enough for a SS then my 4400 will never bend them.
   / JD Loader "Quik-Change" vs. skid-steer? #6
Here is the converter plate I used to mount Skid Steer attachments to my JD - About $500 - Made by ATI. So far I have a Fork lift from King Kutter - A blank plate is available from Bobcat for about $75 - With the plate you can mount anything you can come up with. /forums/images/graemlins/cool.gif
   / JD Loader "Quik-Change" vs. skid-steer? #7
Bobcat Blank Plate
cwave,
How hard is it to switch back and forth between the adapter and a "factory" attachement i.e. bucket? If that's a quick switch sounds like an all-around winner.
   / JD Loader "Quik-Change" vs. skid-steer? #9
Easy as opening a computer case - Drop your JD loader bucket - hang the ATI converter on the loader arms and lock in with the lynch pins (same one's used on the bucket). Go pick up your Skid steer attachment and lift off the ground - Push down on the two lever handles you in see in the ATI attachment above - (line up the holes please!!!) - be on your way. /forums/images/graemlins/cool.gif
   / JD Loader "Quik-Change" vs. skid-steer? #10
The drawback to this system is:
another set of connections between your loader and the skid steer attachment
Weight of ATI attachment piece
Your skid steer attachment is about 3 inches out further from the front of tractor
Available for most brands of tractors - I bought mine thru local Bobcat - shop around for price.
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2017 CATERPILLAR 320FL EXCAVATOR (A51242)
2017 CATERPILLAR...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
Takeuchi TB260 (A50120)
Takeuchi TB260...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
