JD L130 Replacing elect. clutch
/ JD L130 Replacing elect. clutch #1
Paul1952
Gotta replace this thing. Anyone know where you might find some instructions on this, diagram, and also how complicated is this going to be? Any help is appreciated.
/ JD L130 Replacing elect. clutch #3
Paul,
Once you get it changed try to limit the use as much as you can, and engage at low speed. I haven't had near as many problems since I started being more careful with it.
/ JD L130 Replacing elect. clutch #4
I always feel like every engagement of the PTO clutch on my LA145 may be the last one because of the shock load with a 48" or 54" deck. When I was looking at X320 mowers for my brother, I was astounded how smoothly the electric PTO clutch engages on those. I believe the L130 has the same clutch as my LA145 and is just an example of many items that are high maintenance on these low-end JDs. The one on my LA145 broke the retainer strap and ripped the wires out of the connector plug last year. I repaired it and added an additional stiff spring to absorb some of the shock in addition to the strap. So far, I haven't had anymore failures.
The way this clutch feels reminds me of the clutch I had on an old Datsun 240Z. When I replaced the clutch plate, they gave me one for a 4-cyl Datsun pickup instead of the correct one, and I didn't notice. The replacement had only 1/2 the springs on the center hub as it should have. Everytime I left off the clutch, it would shake and shudder. Finally it self-destructed the clutch because the shock got to it. I took it to a local shop for repair and he showed me the clutch and explained the difference after fixing the problem. It made a huge difference.
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
Kubota Z232 (A60462)
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2014 FORD F350 4X2 S/A DUMP TRUCK (A59914)
2014 FORD F350 4X2...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
