JD L130: Is it the seat swithch?
   / JD L130: Is it the seat swithch? #1
hunting404
SE Wisconsin
Kioti CK20, John Deere L130
The mower has 224 hours. The clutch for the mower deck has been replaced. After shutting it off it would not start. I tested the batter, 12+ volts. Current seemed to be flowing to the starter. Finally, after wiggling the seat safety switch the mower started.
Today the same problem. It ran fine until I shut it off and then tried to start it again. I figured it was the seat switch again and tried to make a jumper. It ran for 2 seconds then stopped.
Is it safe to guess the problem is the seat safety switch? Do any auto parts places sell a switch that will work in its place?
Any help will be greatly appreciated.
Jim
   / JD L130: Is it the seat swithch? #2
It is an $8 switch from Deere, and part # GY20073
   / JD L130: Is it the seat swithch? #3
If you made a jumper and jumped out the seat switch and it only ran for 2 seconds then the seat switch isn't the problem.
The seat switch was not the problem. It still does the same thing, only turns a quarter of a turn when attempting to start. Could it be the starter? What else should I check?
   / JD L130: Is it the seat swithch? #5
In your first post you said it ran for 2 seconds then shut off. Now you say it only turns 1/4 of a turn when attempting to start. If it only turns 1/4 turn have you tried jump starting it with jumper cables. Sounds like it could be a battery problem. If it starts by jump starting, check the battery voltage while running. It should be at least 13V or higher. If not it's not charging.
   / JD L130: Is it the seat swithch? #6
Sounds like an new battery needed. They are good for about 3-5 years. Any idea how old this one is?
71059 (A49346)
71059 (A49346)
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
