JD/ Kubota
   / JD/ Kubota #11
JGD,
Good investigative work. You are right - I am wrong. The Kubota UDT bottle also lists John Deere J21A - the J20D bottle (Low vis hy-gard) says "replaces J21A.
There must not be too much viscosity difference between the two JD fluids if Kubota and others can cover it with one oil.
   / JD/ Kubota
Should be changing fluid this weekend, I will post if tractor blows up or grinds itself to bits.
   / JD/ Kubota #13
John Deere Hy-Gard™ Hydraulic/Transmission Oil
Viscosity at 40*C 59cst
Viscosity at 100*C 9.4cst
Viscosity index 140
Pour point *C -40
Flash point *C 227
Properties listed for UDT are:
Gravity, degree API 29.5
Viscosity @ -30°C, cP 18,300
Viscosity @100°C, cSt 9.5
Viscosity @ 40°C, cSt 60.0
Viscosity Index 140
Pour Point, C° max -35
Zinc, % wt. 0.12
For Super UDT:
Specific Gravity @-15.6° .0877
Viscosity @ 25°C, cSt 84
Viscosity @ 100°C, cSt 9.00
Viscosity @ 40°C, cSt 45
Pour Point, C° max -46
Zinc % wt. 0.17
You could also use Amsoil’s tarctor/ hyd in there, Also Chevron AW THF and I think Schaeffers.
I would use whatever is cheaper since there are all very very close.
   / JD/ Kubota
How do you know all this stuff?
2008 JLG 600S TELESCOPIC MANLIFT (A51242)
2008 JLG 600S...
8' GREEN CHAINLINK FENCE (5) ROLLS (A51244)
8' GREEN CHAINLINK...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
