jd,kubota,vs cub 7532
   / jd,kubota,vs cub 7532 #1
bobwire
Missouri
Hello everyone, I am new to this forum and I was hoping you guys could help me! I am in the market for a utility tractor, I have about 12 acres to brush hog and 5 acres to mow. I have got prices on JD, Kubota, and Cub 7532 all with a loader. I see alot of threads on JD and Kubota but not Cub, is Cub one I should stay away from? And what hp range should I be looking at. Thanks for any help you can give me.
   / jd,kubota,vs cub 7532 #2
Why don't you please fill out your profile to provide us with some more details, it will help us sort out some things like climate, conditions, etc.
Do you have 12 total acres? Or 12 acres to bush hog? Lot size, job task lists and how much of your land you use is going to be much of the basis for what size/type of tractor people would recommend.
Bob,
I updated the profile page "I think" hope this will help!
   / jd,kubota,vs cub 7532 #4
The Cubs are the same as the Mahindras and Kiotis (depending on size) that have yellow paint schemes and bigger prices.
   / jd,kubota,vs cub 7532 #5
If I were you, I'd check out the CC 8354, which is a rebadged Kioti DK35, then go buy a DK35 from a Kioti dealer unless you can get the CC for less. I much prefer the Daedong engines over the Mitsubishi engine found in the model you're asking about.
BTW, it's not a good idea to post the same question all over the forum as it causes much confusion for the readers trying to find and keep up with the thread in which they answered you. It's best to make one post in the Buying/Pricing/Comparisons forum, unless you're asking about ONE specific brand, and then you'd use that brand's forum.
John
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2010 MACK PINNACLE (A52472)
2010 MACK PINNACLE...
2011 FREIGHTLINER M2 (A52472)
2011 FREIGHTLINER...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
