Oil & Fuel JD injector leaking
   / JD injector leaking
You are correct about the hose from JD. The original hose was smaller dia but rubber. When I removed the return assy, the hoses were soft and slid off the nipples without depressing the clamps. When I picked up the parts, I asked for the correct clamps and was told "those are special order".
The o rings in the breakdown are seals for the injector nozzles. The copper washers sean the nozzles to the injector. I might have been able to replace the injector hoses without removing the return assy but I was not positive that it was only the hoses between the injectors.
The R&R on the return assy requires the steel injector lines be removed. Much larger job. Installing the o rings on the injectors required finding and cutting a thin plastic tube to go over the injector threads to protect the o rings from damage while sliding then down to the grove.
Because of the years I have owned the tractor, I replaced all the fuel lines. As I was putting everything back together, I thought back to when the problem started. I keep the fuel tank full all the time. I had topped off the tank the day before. I removed the fuel cap and could hear the poppet in the cap when I turned it over. I put an air nozzle to the inside and as I blew air into the inner vent hole, nothing came out the top. As I increased the pressure, the vent cleared. I think this might have been a factor in the problem. The engine runs again and no fuel leaks.
Thanks for all of the insight. Diesels were never my forte when I was in business. You are never to old to learn. Ray
2009 BMW 3281 CONVERTABLE (A57192)
2009 BMW 3281...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
CFG Industrial NT18K (A56469)
CFG Industrial...
1980 Gleaner F2 with heads (A57024)
1980 Gleaner F2...
2025 KH72 72in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 KH72 72in...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
