JD HYDRAULIC PROBLEM
   / JD HYDRAULIC PROBLEM #11
He may not have the inline filter...it was not standard on the early models.
   / JD HYDRAULIC PROBLEM #12
Thanks a million! Taking the "spool" out and manually raising the 3ph arms squirt out some hydraulic fluid. Reassembly was easy and the 3ph now works normally. What can be done to prevent this from happening again? (It is a lot of work to have to do and I'd like to avoid it if possible.)
Glad to hear you got it fixed:D
2017 Ford F350 (A49461)
2017 Ford F350...
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2017 Ford F-550 Valve Maintenance Truck (A50323)
2017 Ford F-550...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
