HyGuard and HyTran have completely different viscosity profiles. They are quite different oils and are not cross-compatible except to those who think "oil is oil, it all comes from a hole in the ground".
You might want to tell that to IH and Deere since if you look at there spec pages they list them as being compatable. NOTE: CNH MS-1209 & MS 1210 are HyTran
Applications
Hy-Gard hydraulic/transmission oil provides the best performance and wear protection for John Deere hydraulic and transmission systems.
Recommended for equipment with either common system reservoirs or separate transmission and hydraulic systems, including those with wet brakes and wet clutches.
Service Ratings
AGCO
Massey Ferguson: M1135, M-1141,
M1139, M-1143
White: MQ-1722, Q1766, Q-1766B,
Q-1802, Q-1826
Allis-Chalmers, Deutz-Allis, AGCO Allis:
Power Fluid 821XL
CNH
Case, Case-IH: MS-1207, MS-1209,
MS-1210, MS-1
Ford/New Holland: ESN-M2C41-B,
M2C134-D, M2C48-B, M2C48-C,
M2C159-B/C, 159B/C, M2C86-B,
FNHA-2-C-200, FNHA-2-C-201
Caterpillar: TO-2
Clark: MS68
Deutz: Hydraulic transmission fluid
Dresser: Transmission hydraulic fluid
(HMS B806-0002)
Eaton Hydraulic Division: Hydraulic transmission (Form3-401-123)
IHC: B-6
John Deere: All-weather hydraulic fluid
(JDM J21A)
Kubota: UDT hydraulic transmission fluid, Super UDT
Oliver: Type 55
Sunstrand: Hydrostatic transmission
Zetor: OT-H, GL-4
ZF: TE-ML03E, 06D, 06E
Test Analysis
Viscosity @ 40ーC................... 59 cSt
Viscosity @ 100ーC................. 9.4 cSt
Viscosity index.................. 140
Density............................. 0.89 g/cm3
Pour point......................... -40ーC
Flash point......................... 227ーC
