JD Hy-Guard compatibility....??
   / JD Hy-Guard compatibility....?? #1
bswiv
Palatka, Fl
CAT D5G, Kubota M8540, KubotaB2700
Friend gave me about a gallon each of John Deere Hy-Guard hydraulic fluid......low viscosity and regular.......
Not wanting to waste it I'm wondering whether I am safe using it in my Cat D5G for the hydraulic system......or in my M8540 Kubota's hydraulic system?
What is it compatible with?
   / JD Hy-Guard compatibility....?? #2
Pretty much all trans/hydraulic fluids are completely compatible. They have to be when there are so many hydraulically-driven attachments, implements, and rentals.
Hy-Gard is top quality. Look it up. They used to publish a table of other fluids that met the same quality specs.
   / JD Hy-Guard compatibility....?? #3
A gallon? Toss it in with the used oil. Why risk a contamination/compatibility issue over a gallon or two of oil?
   / JD Hy-Guard compatibility....?? #4
JD Hy-Gard & Kubota hyd oils are very compatible. There's no risk involved mixing the 2 brands of oil. I utilize Hy-gard in my Kubota M7040 transmission case
   / JD Hy-Guard compatibility....?? #5
My tractor is suppose to use the low viscosity Hy Gard. They sold me the regular kind for my first change and the low viscosity for the second. I didn’t catch it until the second change so mine is a blend, no problems.
   / JD Hy-Guard compatibility....?? #6
Not sure of the age of your Cat but are you sure it doesn’t use TDTO - Cat’s Transmission and Drive Train Oil, which has different additives than ag hydraulic oil.
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2008 Volvo XC90 Multipurpose Vehicle (A51694)
2008 Volvo XC90...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
