JD GX85 riding mower -- Install flywheel dry or lube? Bendix gear question also.
   / JD GX85 riding mower -- Install flywheel dry or lube? Bendix gear question also. #1
Gene123
Dallas. TX
John Deere SRX75, John Deere GX85
Hello friends. John Deere GX85 riding mower with 13 hp Briggs & Stratton engine. Flywheel -- When putting it on, should lube or anti-seize compound be applied to the shaft and hole, or should it go on dry? Bendix gear -- the plastic bendix gear only engages about 2/3 the way. Is this normal, or should it engage 100% into the teeth in the flywheel? Is it better to use a plastic bendix gear, or an aluminum one?
   / JD GX85 riding mower -- Install flywheel dry or lube? Bendix gear question also. #2
Gene,
No lube on the flywheel shaft or the flywheel.
Richard
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
2010 Club Car Precedent Electric Golf Cart (A53424)
2010 Club Car...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A54313)
2012 INTERNATIONAL...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
