JD GX85 riding mower -- Install flywheel dry or lube? Bendix gear question also.
   / JD GX85 riding mower -- Install flywheel dry or lube? Bendix gear question also. #1
Gene123
Dallas. TX
John Deere SRX75, John Deere GX85
Hello friends. John Deere GX85 riding mower with 13 hp Briggs & Stratton engine. Flywheel -- When putting it on, should lube or anti-seize compound be applied to the shaft and hole, or should it go on dry? Bendix gear -- the plastic bendix gear only engages about 2/3 the way. Is this normal, or should it engage 100% into the teeth in the flywheel? Is it better to use a plastic bendix gear, or an aluminum one?
   / JD GX85 riding mower -- Install flywheel dry or lube? Bendix gear question also. #2
Gene,
No lube on the flywheel shaft or the flywheel.
Richard
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
UNUSED XSTAR 300 GALLON PORTABLE FUEL TANK (A54756)
UNUSED XSTAR 300...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
