JD GX345 Drive problems
/ JD GX345 Drive problems #21
Impact driver is the best tool for that.
/ JD GX345 Drive problems #22
Well I got mine apart and the pulley ordered. Put a new belt on and was going to change the hydraulic fluid an transmission fluid but I don't see any drain plugs. Does anyone have any suggestions?
/ JD GX345 Drive problems #24
Yes I do have the manual and got everything done and back working . Thanks everyone.
/ JD GX345 Drive problems #25
pully came in Thursday. got it back together and mowed that evening. New pulley,drive belt,fluids and filters changed.
/ JD GX345 Drive problems #26
My problem is tractor worked fine til yesterday. Hardly could come up driveway. Only would move with a light pedal pressure.
/ JD GX345 Drive problems #27
IBM
Welcome to TBN
Suggest you explain your problem, if you want help. Give us some history of the GX345 under your care, and also history of what led up to this problem, if anything. History of oil/filter changes etc.
Members here will try to help you with a solution, but will need good background info from you.
SPARTAN XBC173072-72" HYD BRUSH CUTTER (A65056)
SPARTAN...
Sullair 375 CFM Mobile Air Compressor (A68134)
Sullair 375 CFM...
2020 Honda Rancher 4X4 ATV (A66738)
2020 Honda Rancher...
LINCOLN ARC WELDER (A67714)
LINCOLN ARC WELDER...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
