JD GT275 won't start
   / JD GT275 won't start #1
RichOnLopezIsland
Lopez Island, WA
Shibaura SD-1840-FD and JD GT275
I bought used GT275 a couple of years ago, and it has worked well. Except this morning it wouldn't start. I used it just a few days ago. When the ignition is turned on, I hear a click (maybe the solenoid?) but nothing more happens. I have verified the PTO is off, the brake is fully pushed in, the battery terminals are clean, the spark plug connection is good. I noticed in a prior post from someone with a similar problem they disassembled and cleaned the starter solenoid but I don't know where it is. The fuel filter, spark plug, air filter, oil and filter were changed recently. Any ideas?
richonlopezisland
   / JD GT275 won't start #5
Try to jump start it or charge the battery first - if it starts with a jump/charge then get a new battery, if not then solenoid or starter. Also when running check the voltage output to the battery - should be around 13.8V.
   / JD GT275 won't start #6
My last batter was dead, but when I put the charge on it it said it was fully charged. I even tried starting it with the charger attached no dice....new batter and it turned right over.
   / JD GT275 won't start #7
Yep - same thing happened on my 1989 Cub Cadet a year ago - did a full charge but would only start with 100 AMP setting on the charger - so put in a new 365 CCA battery - this is the 4th battery in 24 years so not too bad. I use the trickle charger on all my seasonal machines now - about a month on each one just cycle it around and seems to work.
Subsequent to my original post, now nothing happens, no "click", no dashboard lights. I installed new battery and still nothing. I don't know my way around small engines, so I don't know what the solenoid or starter even look like. If anyone has any thoughts, please post them. I live on a small island and the local repair shop is really business especially during tourist season. I'll look for a local that can help.
   / JD GT275 won't start #9
Make sure that the cable ends are clean and tight ---- check both ends of the cables. Good grounds are essential. Wiggle the ends that attach to the battery ---- those ends have been known to break just inside the plastic cover on the cable --- you can't see it without wiggling the end to feel it. Do you have a VOM? If you do, what's the battery voltage at rest? Next leave the VOM leads attached to the battery and turn the key to start ---- what's battery voltage in with the key in the start position?
   / JD GT275 won't start #10
Well, there are several fuses in the line from the switch - here is a wiring diagram to start to sort out your gremlins. Save this file and print it out to start the troubleshooting.
Get a volt / ohm meter if you don't have one - you can get these for $10-25 at your big box store or sears, or on line too.
CFG Industrial H15R (A53316)
CFG Industrial...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55302)
BOSS 990 Fuel...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
