JD GT275 - Help!!! Deck Keeps shutting down
   / JD GT275 - Help!!! Deck Keeps shutting down #11
This is fairly easy to diagnose. You may have a bad battery or a bad voltage regulator - or both.
However, the fact that you need to charge the battery means it is NOT being charged when the engine is running. What is happening is that the PTO clutch is electrical and when the battery voltage / amperage drops below a certain point the clutch disengages. Since it is not being charged, it only takes a little while for the clutch to drain the battery below the disengagement voltage / amperage point.
The easy way to diagnose the problem is to use an electrical multi-meter. Turn on the tractor and read the voltage at the leads going into the battery. If it is below 13.8 Volts, then the charging circuit is not working. The voltage should be between 14.2 and 14.6 Volts at the battery when the engine is running and revved up to 1500 - 2000 RPM.
If the voltage is okay, then you have a bad battery or the clutch needs adjustment. You can take the battery to some place like AutoZone or other car parts dealer and they can load test the battery. If the battery checks out as okay then it is the clutch.
But, I had the exact problem with my GT275, and the fix was a new voltage regulator board. You can get them from a local John Deere dealer or on-line from a number of sources. The real problem is replacing the board. It is located on the left side of the tractor (as you're sitting in the seat) in back of the center column.
You will have to have someone take off the lower side panel, the throttle cable, steering wheel and loosen the entire center column so that it can be lifted up slightly and tilted back to get at the electronics boards.
You take off the steering wheel to allow the center column to be lifted up, remove the throttle cable from the carburetor so that you can lift up the center column. If the throttle cable is not free, it will not allow the center column to be lifted far enough to tilt it back slightly.
The voltage regulator board plugs into the main board. Once you have the main board out of the tractor it's fairly obvious how to change the voltage regulator board.
It took me about 2 hours for the entire swap out as I had to figure out what needed to be done to access the board. If I had to do it again it would probably be about 1.25 hours as you have to adjust the throttle cable after everything is back in place and that is a trial-and-error process that takes a little time to get it to run from idle to full throttle at the full throttle detent.
   / JD GT275 - Help!!! Deck Keeps shutting down #12
I see you're way up in the thumb. I'm north of Flint and have the same mower. If you need someone to help you out shoot me an email. I'm no mechanic but from the sounds of it these gentlemen can walk me through the troubleshooting/repair steps for the PTO. I wouldn't mind learning how to for myself and helping out someone in need at the same time.
   / JD GT275 - Help!!! Deck Keeps shutting down #13
That is a nice offer to help out, hope the new battery solves her problem though.
   / JD GT275 - Help!!! Deck Keeps shutting down #14
I am not familial with this mower but my neighbor has a Cub Cadet that shuts the PTO off anytime to put the thing in reverse.
If I bought a new mower with this feature the 1st thing I would do is find out what switch to jump out, or rewire something.
Engaging a PTO clutch wears out the clutch plus the belts, and I have to back up at several corners all over my yard.
Sometimes safety hampers reality.
   / JD GT275 - Help!!! Deck Keeps shutting down #15
I'm not sure what this comment has to do with the OP's problem. The GT275 does not have a reverse PTO cutoff. The problem, as described, points to a battery not being charged. This is usually caused by the voltage regulator board failing so that the battery is not kept charged and no additional electricity being available when the PTO is engaged. It is not an uncommon problem with the GT 200 series tractors. The GT275 was manufactured from 1995 to 1998 so it can be from 16-19 years old - things break and wear out.
   / JD GT275 - Help!!! Deck Keeps shutting down #16
I have a jd345 that the pto will stop while mowi ng.. Does any one have any suggestions.. Thanks jim
   / JD GT275 - Help!!! Deck Keeps shutting down #17
Check battery and charging rate after the basics. The electric PTO is a high current device, so it needs a functional supply to stay engaged.
   / JD GT275 - Help!!! Deck Keeps shutting down #18
had the same problem it was the switch 30.00 at the dealer. parts guy said it was a common issue
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
2014 UTILITY DRY VAN TRAILER (A51222)
2014 UTILITY DRY...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
