jd grain drill
   / jd grain drill #1
cea74
texas
jd 4020
hello i have a old jd grain drill how do you id the model number thanks
   / jd grain drill #2
It would help if you describe it or post a photo. Does it have an even or odd number of seed openings? Is it a plain grain or does it also apply fertilizer?? What color are the seed box lids and are they flat or curved??
   / jd grain drill #3
also look for any cast in p/n's they sometimes can help you w/ the jdparts and going that way if not too old.
   / jd grain drill
   / jd grain drill
it has 16 seed openings,plain grain,yellow flat top also found this #DR1610B001277M
   / jd grain drill
ok thanks i can start looking for parts
   / jd grain drill #8
Yep it's a DR 16 seed openings,10" spacings between seed openings & SN 1277
   / jd grain drill #9
Nice old drill. Can't see from your photos if it has trip clutches to raise and lower the openers or if there should be a hydraulic cylinder to handle that operation. I restored a pair of Minnepolis Moline P3-6 drills (10 ft wide, 20 drops, 6" spacing) a few years ago. One of them had the trip clutches. The other was hand operated so I rigged up a hydraulic cylinder to raise/lower the single disc openers.
Good luck in your restoration project.
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
1985 International 1754 Material Spreader Dump Truck (A51691)
1985 International...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
