JD Gator XUV Rim And Tire Help Needed.
   / JD Gator XUV Rim And Tire Help Needed. #1
WOEII
Tires and rims that are currently on the gator are:
AT-489
Front 25x10.0 -12
Rears 25x11.0 -12
Over the holidays I picked up a smashing deal on Ebay for a full set of OEM JD rims.
The rims say:
Front 12x7
Rears 12x8
Here is my question. I have been eyeballin the Grim Reaper tire but I am not sure what sizes would fit on my new rims. I would like the largest possible for the rim and that would fit ok on the gator and not cause problems. I just know nothing of tire and rim measurements and how it works. :(
Any help and and comments on my project would be greatly appreciated.
   / JD Gator XUV Rim And Tire Help Needed. #2
Is it me or do those rear wheels appear to be more than an inch wider than the front...
Measure the overall height of yor existing tires to maintain clearances and buy a tire that has that height and will fit the rim width that you bought...Shouldn't be a big deal.
   / JD Gator XUV Rim And Tire Help Needed. #3
Hope you are right about their being JD Gator compatible wheels. They look like they have quite a bit of offset on the wheel spider, almost like they are for a FWD car. That puts the center of tire quite a bit inboard. This reduces inside wheel clearance and also reduces rollover stability. (Nice looking wheels, though).
   / JD Gator XUV Rim And Tire Help Needed. #4
Good point about the offset...They look really wide. I've seen that style on ATV's/UTV's before, but who knows...Looks to have the right number of lugs:D
They are stock OEM XUV rims. :)
Wheel features include:
Advancecast process allows the creation of a strong, lightweight, and great-looking one-piece aluminum wheel.
The alloy wheels use a bright, diamond-cut machined finish with clear-coat protection.
Green/Yellow XUV 620i and 850D vehicles will have powder-coated yellow wheels with machined areas and clear-coat protection.
Specifications:
Two front wheels, 25x10-12 with AT489 aggressive tread tires (tires are not included in field conversion kits)
Two rear wheels, 25x11-12 with AT489 aggressive tread tires (tires are not included in field conversion kits)
20 silver-plated wheel bolts
Four custom silver-plated steel valve stems and caps
Four custom wheel caps with the leaping deer logo
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
RoGator 844 sprayer (A50490)
RoGator 844...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
