JD Gator XUV Rim And Tire Help Needed.
   / JD Gator XUV Rim And Tire Help Needed. #1
WOEII
Member
Tires and rims that are currently on the gator are:
AT-489
Front 25x10.0 -12
Rears 25x11.0 -12
Over the holidays I picked up a smashing deal on Ebay for a full set of OEM JD rims.
The rims say:
Front 12x7
Rears 12x8
Here is my question. I have been eyeballin the Grim Reaper tire but I am not sure what sizes would fit on my new rims. I would like the largest possible for the rim and that would fit ok on the gator and not cause problems. I just know nothing of tire and rim measurements and how it works. :(
Any help and and comments on my project would be greatly appreciated.
   / JD Gator XUV Rim And Tire Help Needed. #2
Is it me or do those rear wheels appear to be more than an inch wider than the front...
Measure the overall height of yor existing tires to maintain clearances and buy a tire that has that height and will fit the rim width that you bought...Shouldn't be a big deal.
   / JD Gator XUV Rim And Tire Help Needed. #3
Hope you are right about their being JD Gator compatible wheels. They look like they have quite a bit of offset on the wheel spider, almost like they are for a FWD car. That puts the center of tire quite a bit inboard. This reduces inside wheel clearance and also reduces rollover stability. (Nice looking wheels, though).
   / JD Gator XUV Rim And Tire Help Needed. #4
Good point about the offset...They look really wide. I've seen that style on ATV's/UTV's before, but who knows...Looks to have the right number of lugs:D
They are stock OEM XUV rims. :)
Wheel features include:
Advancecast process allows the creation of a strong, lightweight, and great-looking one-piece aluminum wheel.
The alloy wheels use a bright, diamond-cut machined finish with clear-coat protection.
Green/Yellow XUV 620i and 850D vehicles will have powder-coated yellow wheels with machined areas and clear-coat protection.
Specifications:
Two front wheels, 25x10-12 with AT489 aggressive tread tires (tires are not included in field conversion kits)
Two rear wheels, 25x11-12 with AT489 aggressive tread tires (tires are not included in field conversion kits)
20 silver-plated wheel bolts
Four custom silver-plated steel valve stems and caps
Four custom wheel caps with the leaping deer logo
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
78'' rock / skeleton grapple (A56857)
78'' rock /...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2017 John Deere 1025R Tractor - 626 Engine Hours (A55315)
2017 John Deere...
