JD Gator with the best low-end pulling capability
   / JD Gator with the best low-end pulling capability #32
I own a Gator 6x4. I do not think the transmission in a gator is designed for ground engaging euipment use. I have never used mine for ground engaging equipment work but have tried pulling a couple of things. For pulling one had better have the bed on the gator full or near full to obtain all the down force weight possible. With the bed full and the gator coupled to something heavy with a chain for towing the belt will start to slip. With the bed empty the wheels spin. I would suggest a small cut with a loader and weight box.
i pulled well over 6k lbs with my 04 hpx and never had a belt slip never burned up a belt . you must not have had a belt enclosure on yours. but then again you had the 6x4 and it didn't come with an enclosure so thats a good reason why you had slipping.
2017 John Deere 6120E (A53317)
2017 John Deere...
2024 CATERPILLAR 305CR EXCAVATOR (A52707)
2024 CATERPILLAR...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
Rooster Weathervane (A55853)
Rooster...
2017 Ford F-650 Mason Dump Truck (A56858)
2017 Ford F-650...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
