JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE*
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #11
i do live in the deepest of south louisiana too where it's always hot even in the winter.lol so this choke thing would probably be good for anyone who is in a cooler climate than me
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #12
Kyle in Tex,
Do you have a part number for the new carb? I have an 02 mule that is such a pain in the butt to crank. I too have drilled out the brass buttons and have adusted those screws many times. I'm considering just ordering the new carb and being done with it.
Ken
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #13
I can get you one but I'm at work right now.
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #14
Bigk56,
Here is the JD part #: MIA10675
The JD label is glued right over the Kawasaki part #15003-2996
JD had it stocked in the warehouse and I had it in 3 days w/o paying any shipping.
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #15
I experienced all the problems discussed in this thread with my 2004 JD Gator HPX. Difficulty starting in any condition (hot or cold), needing to pull choke and give gas to start, minor backfiring while driving, only one spark plug was black, etc. I replaced the fuel filter, air filter, cleaned the old carburetor and complete service without success. Finally, I purchased and installed the replacement carburetor today (part# MIA10675). Perfect! The HPX now starts without even pulling the choke every time. I even left it outside for 2 hours and was able to start it with ease - first time! No backfiring and running perfectly. I am convinced there was an inherent flaw in the original carburetor. It was $500 well spent. Let me know if you have any questions.
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #16
Glad you got your machine fixed. It will be a lot more enjoyable now to drive.
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #17
My 610 was a miserable thing to start from day 1. So bad in fact that I couldn't keep batteries in it. the starter would run them down to the point that the charge system couldn't keep up. even went to 400 amp utility battery. Then I checked the spark plug. manual calls for .028-.032" gap, I opened it up t0 .040" and it is like a new machine. easy start and all.
amazing how something so simple can cause so much grief.
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #19
Our '08 HPX has always started quite easily since getting it in June. In fact, in another thread (or maybe this one-I should check) I reported that it was necessary to push in the choke almost immediately after starting to keep it from stalling, and choke was never necessary after the first start of the day.
Well, last weekend it was in the 20s here in New England, and i found i actually needed to leave the choke out for 40-50 seconds after starting, in order to keep it running. And, it wanted a brief choking after sitting a while in the cold. I'm really impressed with the fact that this engine isn't at all reluctant to run or pull within minutes of starting.
Just posting this so others will know that at least our HPX starts easily and runs well from cold. The salesman suggested we consider the 620i for improved cold starts, but our experience suggests that wasn't important.
   / JD GATOR STARTING PROBLEM (KAWASAKI ENG.) *UPDATE* #20
This is the best advise ever! I did it too, and WOW! now I have to lower my idle, because it runs so much better! Thanks for the tip. Dave
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
John Deere 4510 (A53317)
John Deere 4510...
