JD Gator electrical troubleshooting
   / JD Gator electrical troubleshooting #11
I have a J.D. Trail Gator that starts fine, but when you put it in gear it shuts off. Am I having a safety switch issue? And if so, where is it located? Thanks for your help.
   / JD Gator electrical troubleshooting #12
:welcome: to TBN
What year is the gator?
Are you aware of any safety switches other than "no start" if in forward or reverse? Mine is older 4x2, and that is the only switch I'm aware of on there.
Does it happen in reverse as well as forward?
   / JD Gator electrical troubleshooting #13
Not sure of the year. Actually belongs to my boss. It shuts down in either forward or reverse. My son said that when he was coming to a stop it shut down when he pressed the brake. Thank you for your help.
   / JD Gator electrical troubleshooting #14
But it starts no problem if putting in neutral??
Indicates electrical, shorting out the ignition.
But if "shut down" means it is killing the engine when put into gear, then might be in the tranny and may explain the son's experience when he pressed the brake.
Need more info...
3PT PTO POST HOLE DIGGER (A52708)
3PT PTO POST HOLE...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
Mini Excavator (A55787)
Mini Excavator...
jet ski trailer (A56859)
jet ski trailer...
GRILL GUARD FOR JOHN DEERE 5000 SERIES TRACTOR (A52708)
GRILL GUARD FOR...
