JD F935
/ JD F935 #1
Mower Mac
98 jd f395
Hopefully someone can help,just picked up this mower been sitting for a few yrs. It runs excellent but it had one wheel that would not roll so I loosened the brake so it would roll but when I put the pedals for forward or reverse it just creeps push pedal farther down it kills motor. what could be the problem the parking brake and brake pedals seem to be froze up.
/ JD F935 #3
run it slow and keep it running and moving. Then check the brake drums for heat. Bingo if one or both are more than warm.
Answer this first then move to hydraulics: Lift cylinders both work when stopped ? Load transfer valve works ?
/ JD F935 #4
Engine stops as in fuel cutoff, or something is jammed up ? Pull ff the wheels, then the brake drums via the large nut. Save the stamped locknut. Now watch the axles as you try to run it.
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
Rotomec PHD 300 (A64126)
Rotomec PHD 300...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
