BHD
Veteran Member
I have 1971 john Deere 4000 tractor, (striped down 4020)
it has approx. 10,000 hours on it original pump was fixed, I am guessing about 4000 hours, (did not know about the fuel tank drain and got water in the pump was the needed fix, I do not remember what they replaced,
I up graded the filters and learned to drain the water out of the tank,
but that besides now,
I am having some governor issues, and I am guessing the head is wore as well, the way it starts some days, or does not start,
any why I see places that "fix" your pump, and places that say they rebuild your pump, to like new specifications,
and prices ranging from $1020, the high end (John Deere) part SE500559.
On most ranging in the $700 to $800 for what they call rebuild, the high to $330 on the low, send them your pump,
(yes I know the $330/$400 is a fix it place), and will call if more work is needed, (I do not want to pay for pie in the sky either)
THE QUESTIONs
ONE Does JD do a better job of rebuilding? or are they just charging you because it is green?
I like the idea of going in pickup up the pump coming home and replacing it that afternoon and not be down for a few weeks,
most of the other places I have called do not have a pump on the shelf, and they say send me mine and they will rebuild for $800,
I found two places one $330 and the other About $400 labor and to replace the normal wear items and gaskets, and if more they will call, I asked what if more is needed and they said add about $300 for most worst case, if it is not stuck, mine is still operational, but like I said it most likey needs a head, or $700/$800 worth of work, but do not know for sure,
I would think with 6000 hr, if not 10,000 hours it would need to complete parts kit of all moving parts,
what would you do, and do you think JD does a better more complete job? (they claim they do)
the original pump is a JDB633AL2402 AR50146
THE QUESTIONs
