JD CT332 Track Loader, Stalling
/ JD CT332 Track Loader, Stalling #1
Tom Tractor
On occasion and just yesterday my Ct332 has stalled shortly after running and it's extremely difficult to get restarted. In the past I will drain the fuel/water filter, bleed the line while priming as the manual says. But it often takes quite a while to get going. The last time it happened, I changed the fuel/water separating filter, the in line fuel filter and air filter without any luck. A service guy finally came out and got it started, but I wasn't there to see what he did. I'm not sure if it's water or air in the fuel line. The in line fuel filter is half full, but I can see fuel enter it when I push the prime button. Any suggestion would be appreciated. Thanks TT
/ JD CT332 Track Loader, Stalling #2
Call and ask the service technician what he did to fix the problem and let him know it is not really "fixed".
Today, I did call the service place. They won't be able to get back out until a week from Friday. He read what the service guy wrote on the work order. States basically what i do. A stone mason whom was here stated he blew out a line. I not sure what line he would blow out. There appears to be four lines. Any Ideas.
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
2018 Deere 672GP (A64126)
2018 Deere 672GP...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
