JD CT322 Hydaulic leak
/ JD CT322 Hydaulic leak #1
ColdBlackWind
Trigonia, Tn.
Farmtrac 60
I am trying to locate a major hyd leak on this machine. It dumped all the hyd fluid out in the belly pan and after raising cab I can’t find a busted hose or fitting. Any suggestions on how to t-shoot? The only thing I know to do is fill reservoir and lower cab in order to spin the motor hoping I can open it back up and find the leak.
/ JD CT322 Hydaulic leak #2
Is there no option to spin the motor with cab and floor pan removed? Not sure how else to find the leak.
I have had that suggested. I am not well versed on the interlocks in the hydraulic system that prevents any function from working until parking brake is disengaged. I was going to use a remote start button and try to spin the motor with cab up. Just don’t want it to mov because the control levers with the cab up are all the way forward.
/ JD CT322 Hydaulic leak #4
Cold
Not sure either on how the interlocks work on that unit. If Joysticks are not in neutral position it may try to move.
Maybe try putting less than 5 PSI air pressure in reservoir to see if oil bubbles out anywhere. Just be careful so don’t go over 5 PSI or you could damage something.
Cold
Yes sir. Going to try easiest path first. I can lower cab and crank it over briefly, raise cab and look. If nothing else it will probably eliminate some areas. Hard to believe I can’t see whatever busted. It drained the entire reservoir in a minute. We did hear a loud pop so I know it is something big. Hopefully it is a hose and not a valve or the pump.
/ JD CT322 Hydaulic leak #6
If you heard a "pop", raise the cab and carefully feel around on any accessible lines for busted wires sticking out of the rupture.
Have you dropped the belly pans and inspected?
/ JD CT322 Hydaulic leak #7
What were you doing when you heard the pop?
Would suspect one of the high pressure drive hoses or implement pressure hose if drained that quick. Both are most likely a real pain to access and change.
We heard the pop while my son was bumping the left control stick in forward direction at idle. I was prying the track up onto the forward idler. Immediately heard gushing of oil in the pan. I have felt all the hoses I can access for exactly what was mentioned. The machine is in the mud. In the woods and I can’t raise it using bucket because of no hydraulics 😞. I did remove the guards on the left side drive motor but haven’t found a leak there either. I wish I had thought of using air pressure in reservoir before I refilled it. Probably could have found air leak pretty quickly.
/ JD CT322 Hydaulic leak #9
Sounds like typical break down location of away from buildings and in the mud…
From what you are describing I would suspect left side drive hose but could be something else. If it is a drive hose it will leak without moving due to charge pump supplying oil to that line. Have replaced hoses on couple different skid steers and they were a pain to work on.
I replaced a hose to right hand drive early on. Less than 900 hours. Chafed on window through belly pan to drive motor. Just bugs me that I can’t find this one. I will get it. All the suggestions are appreciated.
Found the leak. Left drive motor hyd hose. It was in a 90 degree bend and pressed against the belly pan. I couldn’t get my hand under it when I was feeling for a rupture. Not an easy fix but in the grand scheme of things it could have been worse.
Good job!
Let the cussing begin. 😄
Yes sir. Did the other side a few years back. Wasn’t easy. I do like knowing what is wrong so I can get started getting it back going instead of searching for the problem.
Good call. After starting it for a few seconds I could hear the leak due to the air in the lines. I popped the cab up and was able to see oil running down the pan. The hose busted on bottom side where it was pressed against the pan. I had a torn a tendon on my right middle finger which was splinted and wrapped so I was operating one handed and just missed it on my earlier attempts.
/ JD CT322 Hydaulic leak #15
Glad you got it fixed. Skid steers feel like working on tangled spaghetti in a sardine tin..
2249E037-A5A5-4D42-A803-51E76C5F14E8.jpeg52328DBB-9C67-482B-9D7A-C76BD1CA1A4F.jpeg405C9E2B-4CD6-4B6F-8C10-D5D3C14B5F5A.jpeg
Thought I would share this. Got the hose off this morning. No problem actually. Had a new hose made up locally. I told the folks there what my problem was around the hose bearing against the steel floor pan. They sold me some neat hose guards to try. The hose was also showing signs of wear where it lays between the two other hoses that run to the drive motor. We put a sleeve on it to help that. I have attached pics of old hose and new hardware.
(3) Pieces of 30' Sticks of Heavy Wall Poly Pipe (A62679)
(3) Pieces of 30'...
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
Gravely Zero Turn Mower (A64194)
Gravely Zero Turn...
2015 TEXAS PRIDE GOOSENECK TRAILER (A65643)
2015 TEXAS PRIDE...
Woods Brushbull BB60 3-Pt Rotary Mower (A66285)
Woods Brushbull...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
