JD backhoe on a NH
   / JD backhoe on a NH #11
No research needed, I own one. So do lots of other folks.
And you can get any hoe you want and I wont blink an eye one way or the other.
Just don't tell me it's a common thing for 3pt hoes to break tractors because it's not true.
   / JD backhoe on a NH #12
I think you are responding that way cause you made the mistake of buying a 3 point backhoe without doing research first.
   / JD backhoe on a NH #14
There has been several threads here over the years regarding tractors " Breaking " in half with backhoe's attached , Specifically N.H. tractors and cracks in the bell housing areas BUT Although I have asked , 1) Unsure if 3 point or subframe and 2) Unsure if standard transmission or HST model . Also Unsure " How " top-link was attached , In other words , How much pressure was applied to top link . When attaching my 757C to my TC 30 HST , I can use down pressure on boom and really pull up a lot of slack in the top link , BUT I DON'T , I simply back into hoe , use stabilizers to raise and align , then back completely into hoe . Attach front pins , then hook up top link , raise stabilizers and snug up top link with hoe in basically a " Travel " position . There is no movement in backhoe while traveling or using and there is little if any torquing of tractor between front sub frame pins , back hoe and top link back to tractor .
My belief was that people were over tightening the top link thus shifting the pressure point farther up the tractor into the bell housing .
Fred H.
   / JD backhoe on a NH #15
Just read this post Willl I just bought a Case/Davis D100A mini 3 point backhoe, I want to mount it on my Beaver-3 18hp tractor
Now for many questions, is tractor big enough ?, do I need a sub-frame? Thanks in advance.
sally Brown
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
2012 International DuraStar 4300 Flatbed Truck (A55973)
2012 International...
MONTANA MOUNTAINEER 5TH WHEEL CAMPER (A52708)
MONTANA...
2017 Ford F-550 Cab and Chassis (A56858)
2017 Ford F-550...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
