JD backhoe on a NH
   / JD backhoe on a NH #1
KsM715
I have a NH tc29 (2000 or 2001model year, cant remember which) and wondering if its possible to put a JDpro900 backhoe onto this tractor. I know Ill need a sub frame (I know to stay away from 3pt backhoe attatchments) but I cant find any specs online about this hoe so I dont really know just how big it is.
Any info would be greatly appreciated.
They tend to break the tractor in half.
Exactly. and Im not just using it to dig trenches in nice soft topsoil. it would be used primarily to dig out rocks. (I realize I would have to work at it and go easy)
Looking at the pdf from the ealier post it almost looks like its on a quik attach plate. I have a friend that is a cert.welder and works at Cat.Work tools building buckets and blades. wonder if a sub-frame could be built to bolt this to and run the hydros off a pto pump? (I dont have rear remotes, something else I would like)
   / JD backhoe on a NH #9
A broke in half tractor should be pretty common then given the number of 3pt hoes out there.
Not.
Not.
Do some research on the net about it and you'll see. Granted most of the time people say that with care and proper usage a 3pt hoe will be fine. However, how many of us (men and tools) will not go beyond what the machine can do just to get the job done? I know for a fact that I would break it in half on the first day. While building my rock wall I rented a mini excavator to dig out some rocks that were in the way of my footing. More than once I had that mini with all the weight of the machine off the tracks and up on the blade trying to "get-r-done". I know enough to not even think about a 3point hoe in my situation orits going to cost me way more than it should.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
Wood Fence Posts (A50121)
Wood Fence Posts...
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2019 John Deere 331G Compact Track Loader Skid Steer (A50322)
2019 John Deere...
