JD attachments on BX2230?
/ JD attachments on BX2230? #1
Tags
Platinum Member
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
I was just wondering if anyone makes adapters to run front mounted attachments from a JD sub-compact to the 2230. I only ask because I have a friend that is selling a broom and snowblower cheap.
/ JD attachments on BX2230? #2
They might have been made by the same manufacturer, so you might be able to purchase parts to make them work with the Kubota, but you might spend more than it is worth in the end.
/ JD attachments on BX2230? #3
Both those attachments use the front PTO, not worth the adaptation unless you can get them for free.
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
Kubota L175 Tractor (A62613)
Kubota L175...
FORD 4500 TRACTOR (A64280)
FORD 4500 TRACTOR...
5' Bush Hog (A62613)
1990 John Deere 4955 (A64119)
1990 John Deere...
JOHN DEERE 437E LOG LOADER (A64276)
JOHN DEERE 437E...
