JD attachments on BX2230?
/ JD attachments on BX2230? #1
Tags
Platinum Member
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
I was just wondering if anyone makes adapters to run front mounted attachments from a JD sub-compact to the 2230. I only ask because I have a friend that is selling a broom and snowblower cheap.
/ JD attachments on BX2230? #2
They might have been made by the same manufacturer, so you might be able to purchase parts to make them work with the Kubota, but you might spend more than it is worth in the end.
/ JD attachments on BX2230? #3
Both those attachments use the front PTO, not worth the adaptation unless you can get them for free.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
(4) BOTTOM TURN PLOW (A64280)
(4) BOTTOM TURN...
