JD and Kubota interchange
   / JD and Kubota interchange #1
tricel1
Dalton,Pa.
Yanmar YM336D
I have a Kubota 3130 with the Quick tach system and I saw in the paper a guy has a plow from a JD 4300 with quick tach.
Does the JD interchange with Kubota?
Thank you Ed
   / JD and Kubota interchange #2
I assume you speak of a front mount plow, and I strongly suspect that the two do not interchange with each other (unless you speak of the 3pt quick tach, and not one on the front end).
With 3pt quick tach, I think there is an SAE spec for a standard. If this is of what you speak, then there is a possibility that the two interchange with their respective quick tach systems (I-match for Deere). But this comment doesn't seem to fit with your original question.
Even with a standard SAE spec, a lot of the 3 pt attachments were not made to that spec, but in the future, they may be just so the lesser brands can compete with the big boys.
Bobcat has a system that many of the other mfg's are adapting, just because (IMO) Bobcat has such a large share of the market. I doubt neither Deere or Kubota feel they need to adapt to the other's specs. Know that I could be wrong.
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2019 Chevrolet Silverado1500 LD Crew Cab Pickup Truck (A55852)
2019 Chevrolet...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
Tandem Axle Rear Trailer Frame (A55852)
Tandem Axle Rear...
2015 Ford Escape SE SUV (A55853)
2015 Ford Escape...
